Resets one or all OSPFv3 interfaces to the default settings.
| area_identifier | Specifies an OSPFv3 area, a four-byte, dotted decimal number. |
| vlan_name | Specifies an IPv6 configured VLAN. |
| tunnel_name | Specifies an IPv6 tunnel. |
N/A.
The following command resets the OSPFv3 interface to the default settings on the VLAN accounting:
unconfigure ospfv3 accounting
The following command unconfigures the parameters of the area 0.0.0.1 (and all its associated interfaces):
unconfigure ospfv3 area 0.0.0.1
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
